!!!For those who kept their stock radios!!!!!!
Bling Bling
When sending the output signal to the amps, did you use a hi-low converter from the radios factory signal, or did you interrupt the signal going to the speakers and use that. Thanks in advance.
Originally posted by RMGCL-S:
<STRONG>When sending the output signal to the amps, did you use a hi-low converter from the radios factory signal, or did you interrupt the signal going to the speakers and use that. Thanks in advance.</STRONG>
Tech Guy / Likes to Drive
You'll need a line output converter made for Bose head units, the two that seem to come up on a regular basis when talking to installers are the
SoundGate LOCB (you'll need to buy two) or the AudioLink PD4.
I went with the AudioLink because it has adjustable pre-amp outputs and plugs directly into the factory harness.
Hope this helps.
[ 10-10-2001: Message edited by: Brian Campbell ]
Community Architect
robb m.
robb m.
When I did my install on my CL-S I used a crystalline driver right after the head unit b4 the blows amp....
I ran that signal into an alpine eq/sub controller and had fantastic sound
Puma Jim
20
10-20-2016 11:59 AM
SinCityTLX
20
10-19-2015 11:23 AM
4drviper
09-23-2015 09:00 PM
