Is there anywhere I can buy front door spacers for the TSX?
I have some Alpine SPR-17S Type-R Component Speakers sitting on my floor that I want to install into the front doors, and I'm pretty sure I'm going to need some spacers. I have absolutely no means to fabricate some; is there anywhere I can just buy some?
Also, has anyone run entirely new speaker wire through the doors? What's necessary to get the wire through all four doors?
Good Morning,
I tried to use the honda 6.5" speaker spacers but had no luck as the inside dimension was too small for my speakers. I ended up making my own, but in the process, found out about a website from bullyx2 that might prove useful for you. Check it out:
http://www.edesignaudio.com/edv2/ringbuilder.php
You will probably want 3/4" or 1" thick spacers. hth...
Yeah, i bought mine from them. Think I ended up paying around $20, give or take a couple $, for the pair. Used 1" MDF. Probably would have done them myself, but didn't feel like searching for 1" mdf, and was already ordering some other stuff from them (ordered all of my power and speaker cable from them) Used the old post from elduderino to get the outside diameter, and the speaker specs for the inside. Here's a pic of them installed.
