system setups
Old 04-16-2003 | 03:09 AM
phenom78's Avatar
A-CL Member
system setups
hi agen everyone, im a little "audio" setup illiterate, and im relying on you guys to teach me on how these things work. for example, i know you got the speakers, the sub(s), and amp(s). how does everything connect to each other, and do you need two amps? one for speakers, and one for subs? knoweledge me guys!
Old 04-16-2003 | 07:27 AM
shawhite_RENAMED's Avatar
well lets say that the signal will travel from the headunit to the amp(s) via rca cables.... then from the amp the signal will then travel to the speakers via speaker cable... as for if you need 2 amps or 1 amp it depends on the setup you are going for... are you planning on replacing the stock headunit... what speakers are you planning on going with in the doors...more than likely you will probably want to go with either 2 amps or 1 5 channle amp...
rcs86
08-02-2016 06:52 PM
knight rider
03-04-2016 08:59 AM
SiClone
10-01-2015 10:22 PM
dirleton
09-25-2015 12:25 AM
maharajamd
Console & Computer Gaming
09-24-2015 03:31 PM
Quick Reply: system setups
