System Advice/Suggestions
Hey everyone me again...here's my idea...2-10 inch audiobahn subs in a sealed box looking to upgrade
here's my idea...2-12 inch subs (audiobahn preferably about 1000-2000 watts not worried about amp brand just that it can push the speakers) set up in a box built into the car...the 2 speakers would be put against the back of the seats through the opening of the fold-down seats the speakers would be firing against the back of the seat with a hidden amp setup...with a plexiglass facing the trunk opening showing off the back of the speakers with possibly a neon bar lighting em up :blaze: ()
option #2 would be to have them set up to fire rearward turned slightly facing each other (don't know if you guys comprende but thats the best I can describe ) with an amp setup in between....lastly with a port possibley through the rear deck to keep preassure off the 6x9's
I would also like to get some suggestions of 6.5 mids that would fit easy without modification and 6x9's and probley an amp to push it all (again brand is not a concern just that it can do the job)
CG/Ebony 5AT Non-Navi
20% Tint (MIAMI where its not a mod its mandatory)
Injen Intake
Eibach Pro-Kit (sitting in trunk)
Injen Intake
I wouldn't say audiobahn is trash. If you check .. they blew up pretty big in 1 year. it all depends on what you are looking for.
Yes i recomend JL becuase i have JL. They sound very good and the hit harrrrd. There's other brand that are good .. just depends on what you are looking for. Audiobahn are very good btw .. i had a couple before .. i've yet to try the alumQ 12inch. i hear they sound very good. Boston pros are also good subs also.
That's what I was thinking about the alumQ 12's i really liked the way their stats looked and I've heard they're real good...another question which is better speakers firing right into the back of the seats or firing out towards the back
depends. if you are not sealing the trunk then fire it to the back of the car. if you are sealing the trunk, then fire it towards the seat. Sealing the trunk is where you seal it off at the trunk lid AND the rear deck. so once you close the trunk, the trunk space is like a box, not where you close the trunk and sitll get air thorugh the rear deck.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
