Subwoofer Help!
Old Jan 1, 2003 | 07:58 AM
fusionnv's Avatar
Gimmie my points Biatch!
Subwoofer Help!
Hi Everybody
I wanted to know how long of an amp power wire do we need for a 98 2.3 CL. I see some awsome deals on Ebay for 4 gauge kits. But most of them are 17 and 18 ft. Thanks!
Old Jan 3, 2003 | 06:40 PM
Nihilistan's Avatar
Not sure if this will help, but I bought a 20' kit for my CL ('03). I ran it from the battery, along the factory wiring harnesses through the firewall, down the middle of the car under the carpet and into the trunk. Have about 4 o 5' of wire inside the trunk. If you're going to run it along the sides of the car, you'll probably need more.
-- Nihil
Old Jan 9, 2003 | 10:31 PM
dennis's Avatar
I have the same car as you. My 4 guage is 20' and I ran it from the battery terminal accross the sway bar through the firewall of the driver side back accross to the passenger side and underneath the seat and only have like 2-3 feet left. I also used some for the ground wire. I'd say 20 feet should be fine but 25' would be more than sufficient then you can spare some. If you have extra just used some for a ground YOU DON'T WANT TO BE SHORT. But you alread knew that.
AndrewS
19
Mar 14, 2024 06:59 PM
BoricuaTL
Apr 8, 2016 01:08 PM
kb1rl
Sep 30, 2015 10:17 AM
jmaxima03
Sep 27, 2015 10:22 AM
3GTLOwns
Sep 9, 2015 09:51 PM
