Subs
Guest
Posts: n/a
Subs
I want to add a couple of subs to the system. Is it easy to get to the stock amp behind the seat, and is using the stock lines the way to go. Are those converters worth using? And does anyone know the stock wire diagram for the rear amp?? Thanks in advance.
I'll check my helm to see if I have the diagram and I'll post it if I do. As far as subs go I would add a additional amp if you were going to add a bigger sub in back.
2000 Laguana Green / NAVI, 35% Mirror Tint all over,2 x JL12W6s, Pioneer Premier P920R, MB Quarts Coaxial, PPI 2600.2 and 4400.2 , Pioneer 620 6Disc
My Acura
My Acura
I installed door speakers, 2 amps and a sub and I didn't use any wires from the stock amp. In fact, I took it out of the car! You could splice into the orange wire (before it gets to the amp) and attach a turn-on lead to that, it's 12V Switched!
<A HREF="http://www.acura-tl.com/_borders/TL_in_Pacific_Grove.jpg" TARGET=_blank>1999 ACURA 3.2TL
</A>
Performance:
Comptech Exhausts | Comptech Springs | Versus Turismo Spada 18x7.5 | Michelin Pilot Sport 225/45ZR18 | Future mods: Comptech Swaybars, Coilovers
Security:
Clifford IG9000 loaded with all features & SuperBrite Blue LEDs | Valentine One | McGard SplineDrive wheel locks/lugs |
Audio:
Bose Headunit...for now | Alpine ERE-G190 Sub Processor/EQ | Phoenix Gold ZX400ti & ZX475ti Zero Point Amps | Alumapro BP-10 Sub | Infinity Kappa 63.1 & 52.1 speakers | Custom speaker adapters | PG 1.2 farad Cap | GSI Fused Dist Panel | PIE Line Output Converter | PG wiring & cables | R/F 100-amp circuit breaker |
Effects:
Custom painted rotors & calipers | Burlwood Guage bezel | Dynamat Trunk kit | Levoc pedals | Future mods: Blue neon; Inspire tails
"The digital pimp hard at work."
TL Daddy's pics
</A>
Performance:
Security:
Audio:
Effects:
TL Daddy's pics
Guest
Posts: n/a
I acctually already have the amp (failed to mention that) I was asking to see if it was worth using the the stock cables to convert to RCA to plug in the amp. TL Daddy what did you use for your signal? Did you keep the stock HU?? I want to keep the stock unit so I have to get my signal from there or from the back of the radio.
Mtoker I would greatly appreciate that info if you can get it!! Thanks all for the reply.
InFaMouSLink
10-30-2015 09:43 AM
kb1rl
09-30-2015 10:17 AM
