CL: sub/radio/wiring/ HEEEELLLLPPPP
Old Aug 11, 2011 | 10:41 AM
zshortcut's Avatar
zshortcut
okay so i'm not an audio guru by any means and i've blown both rear 6x9's because the speaker controls and my 2 12's control are the same.
how can i fix this?
new radio? wire different?
any help is a help, Thanks
Old Aug 12, 2011 | 12:24 AM
zerepdivad's Avatar
What do you mean the speaker controls and subs are the same?
What do you have for a deck currently? Factory? Or aftermarket with no sub control?
Generally the better solution is to get a deck with independent subwoofer control.
Another is to install "bass blockers" in line with the rear 6x9s, and another one is to just get a universal rca level "bass knob" such as this...
http://cgi.ebay.com/UNIVERSAL-CAR-AM...item53e8aab872
Old Aug 12, 2011 | 07:24 PM
zshortcut's Avatar
zshortcut
okay i kno i probly sound like an idiot talking about this cause im DEFF not much of an installer but here goes nothing.
on my radio i have the bass booster set to +6 if i turn it down the subs go down and so do the 6x9 woofers
i wanna say the other setting is L+4 M+3 H+3
same thing with that too if i turn the L down the subs and 6x9's go off.
will the bass knob separate the subs from the 6x9's, cause im pretty sure i have to replace them now :/
Old Aug 12, 2011 | 08:03 PM
zerepdivad's Avatar
You will want a deck with independent sub control preferably.
But if you want to save money just get the bass knob. It will only turn up the signal to the amp which is only driving your subs not your 6x9s. Or like i said you can get bass blockers so that you can turn the bass up on your deck, and the 6x9s won't get any of it because of the filters. Either way will work just fine.
Old Feb 22, 2012 | 08:40 AM
99clprem's Avatar
3rd Gear
i agree i have a set of bass blockers on my speakers and have had no problem with the speakers no matter how i have it setup i get crystal clear highs and plenty of bass from the subs
Old Feb 22, 2012 | 06:02 PM
on1wheel01's Avatar
doubt it
Old Mar 11, 2012 | 05:57 AM
MilwaukeeDave's Avatar
Your 6 x 9's should be wired to a rear channel output of your headunit and the subs to the subwoofer channel if at all possible. If you must run them on the same channel you should get bass blockers like they said up there or a crossover for the 6 x 9's.
