TL: SINGLE DIN problem
SINGLE DIN problem
I am using a kenwood deck. Or more specifically a Kenwood MP345U, which is a single din. The problem is that when installing the single din, it doesnt fit right. There is a gap about an inch or so long. What may be the problem. I am guessing it is with the dash kit, but these are the only dash kits offered for my Acura 2000 3.2 TL. There is a gap between the stereo and the cigarette lighter.
When i see what the other people have done, they seem to have double din, as you all realize the factory stereo system is much bigger than the single din. Please help.
Didnt you already post this? You need to post pics or this thread is worthless! Did you buy the metra kit? It should fit the same as the double din kit with out the one inch pocket, or maybe your not installing it right?
Some of the kits are made for multiple vehicles, so you'll sometimes need to snap pieces off for the deck to fit your particular car. I had trouble with mine not too long ago. The directions weren't very clear at all.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
you may just have to trim down the tabs on the dash kit for it to work right
6th Gear
THE PART NUMBER FOR METRA KITS ARE 95-7868B FOR DOUBLE-DIN AND THE SINGLE DIN IS 99-7868 IF YOU DO ORDER THE KIT JUST MAKE SURE YOU READ INSTRUCTIONS METRA IS NEVER WRONG AND ALSO REMEMBER YOU NEED TO ADD THE CD CASE ABOVE THE STOCK RADIO INTO THE AFTERMARKET KIT CANT POST PIKS CUZ IAM NEW TO THE WEBSITE HOPE I HELPED WITH THIS POST
SidhuSaaB
05-30-2020 12:40 AM
