Routing through the Fire Wall?
Old 08-09-2003 | 01:05 PM
cartan's Avatar
Swim Bike Run...
For an 03 CL-S, where is the best place to route a new power wire through the fire wall? How about routing in the engine compartment and through the car? I am putting an amp in the trunk and need to run the power wire back there.
Thanks!
Old 08-09-2003 | 01:30 PM
shawhite_RENAMED's Avatar
there should be a grommet towards the middle of the firewall... if you look inside the car on the drivers side you will see a round plug cut out right above the gas pedal... maybe a little to the right... you should be able to run up to 4ga thru that hole... as far as running it thru the car just go down the side of the car and into the truck...
Old 08-09-2003 | 10:09 PM
SilverKnight's Avatar
Retired. Not available.
http://silverknight.clickhere2.net/sound.html copy and paste link
Marcelechka
Home & Garden
188
09-11-2022 11:53 AM
acuratl26
04-23-2020 07:30 PM
xsilverhawkx
10-05-2015 11:00 AM
Quick Reply: Routing through the Fire Wall?
