Rockford Fosgate 3Sixty.2
I have an 08 tsx with Navi and this seems to be the best option for a better sounding system. Is anyone here running it. Also does anyone have a wire harness diagram for a 08 oem navi/audio system.
I still want to be able to use the navi and bluetooth and by using the stock amps speaker signals, this will convert the signal to rca quality and allow me to utilize aftermarket amps. These are the features it has;
6-channel high-level input
6-channel RCA level inputs (FR/FL/RR/RL/Center/Sub)
Independent 31-band EQ for Front Left and Front Right
Independent 27-band EQ for Rear Left and Rear Right
27-band EQ for Center
10-band subwoofer equalizer
6-channel HP/LP/BP/AP adjustable crossover
Up to 5 feet of delay per channel in 2 inch increments (subwoofer excluded)
Auxiliary RCA input with 31-band adjustable eq
Auto equalization with auto sum capability
Digital Signal Processor with OEM integration capabilities (patent pending)
Remote programmable master volume/aux volume control
Wireless Bluetooth™ [/SIZE]
I'm sure that would work, but using Mercman's harness would be WAY easier and cheaper. His harness is plug and play. You unplug the factory amp, plug his harness into the factory connector and it terminates into RCA's with a remote turn on for your amp. Do a search on here for it.
7thGenAccord
the 360.2 is a great processor if you want to keep your stock unit and still have lots of adjustability. however, if you just need a processor to convert the signals just get the JL audio cleansweep or the RF 360.1.
C'mon, man! Row yer own.
I have JL Audio amps driving four Alpine speakers and a sub, but I've considered the 3Sixty for the eq's and the time-alignment feature. Seems like it's a perfect unit for tailoring the sound to the car's interior acoustics and to my personal tastes. Are there better units for that type of sound-shaping/eq-ing?
InFaMouSLink
10-30-2015 09:43 AM
acuradan69
12-28-2001 02:36 AM
acuradan69
12-28-2001 02:31 AM
acuradan69
12-28-2001 02:28 AM
