Review - Sanyo CCA-BC200 Backup Cam
Finished installing a backup cam the other day and I figured I'd give a quick review.
I got the Sanyo CCA-BC200 because its seemed to have some good features. It is pretty small, has different viewing modes, and has adjustable guides overlaid on the image.
I paid about $250 for it, which is more than a lot of other cameras, but the features on this make it worth it to me. The different modes plus the overlaid guides are worth the extra $$ if you ask me. Its plenty small and real easy to install.
It comes with literaly everything you need to install. The camera itself, a small ECU box, double stick tape, wire taps, cable ties, everything. All the wires are plenty long (except for the switch, but I'll get to that later). Actually the wires are kinda too long, but at least there is no fear of running short.
The default mode is a corrected image view with guides. It attempts to correct the fish-eye view of the camera to give you a normal picture. It works well, but seems to overcompensate a bit. I'm judging just by the bumper line, it seems to bow out a little, but its still much better than the regular fish-eye view.
After the initial set up which requires putting markers at 2, 4 and 8 feet behind your vehicle, the guide lines give you a visual view of how far things are. You can adjust the center point if you mounted the camera off to the side so it compensates. It also lets you adjust the viewing angle. It can simulate a higher angle than the camera is at, giving you a more top-down view, though at greater distorsion. It sets lines at 2, 4 and 8 feet back so you can gauge distance, and you also set side guides so you know the width of your vehicle.
And this leads me to the next view, which is called "AirCam". It actually gives you a full top down view on the area behind your vehicle. It gets a little distored towards the edges, but its a really cool feature.
And the 3rd view is raw images, fish-eye view with no guides. boring.
Heres some pics:
The corrected Image View:
AirCam View:
Install Tips:
I installed it in my '06 TSX following the directions here: https://acurazine.com/forums/audio-video-electronics-navigation-22/backup-camera-diy-362179/
I installed the ECU on the trunk lid, under the carpet. It fits nicely there and made it easy to run the wires. Tied the power into the reverse lights, however I may change this. It takes a couple seconds to power up, which doesnt seem like a lot, but think about how often you are in reverse. Only a couple seconds at a time, right? I think I am going to wire it up to an accessory line instead. It also has a remote turn on lead which I can leave hooked to the reverse lights. The wires are stupid long so I have them all bunched up under there as well. The only wire I need to be long, isn't. The wire for the switch won't make it to the front of the car from the trunk lid, so I'll have to splice some wire to it. Thats for another day though. You really only need the button for the initial set up, or to switch modes. I prefer the default mode though so no real need for it. (other than to show off the AirCam mode
All in all, it's a great product. I give it
Heres some pics:
AirCam View:
Install Tips:
Thank you so much for trying out this camera. There are absolutely zero web user reviews or reports about others who have used this exact camera on their cars. I'm glad to see a fellow tsxer has tried it out successfully! I got the wendy cam, and I would have purchased the Sanyo if I had seen more reviews and could justify the extra coin
Again, thanks for posting this writeup. Maybe I'll go with it in the future.
A few questions, do you find the aircam mode useful? And looking at your picture of the corrected view mode, do the colored markers move as you turn the car diagonally left and right? Or are the markers static on the screen?
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
One more thing. Perhaps you can remedy the problem with the wires from the "mode" switch by mounting the control box up front under the glovebox? Of course, this means you'll have to run all the wires from the cam, to the nav box, to the front of the car
Originally Posted by Fulani has a TL
Great write up. Is the camera as noticeable as it is in the pictures?
Originally Posted by jay427
I've been wanting one for about a year now but have been looking for a more high-end camera than Wendy's. How is this one at night?
Haven't gotten around to it yet, but it's not hard. Just have to extend the wire and run it up to the front. If you've ever wired an amp, it would be pretty similar to running the remote wire from the trunk under the door sill molding up to the front. Honestly though, I'm perfectly happy having the default view, don't feel the need to switch and thats part of the reason I haven't gotten to it yet.
Well, its 2 wires. I was just thinking about running some small gauge speaker wire though, so no more difficult than running a single wire. Its a momentary switch, not sure exactly how it works though. You may be able to run just one wire, depending on how it works, though it would probably be a neg, not a pos (+)... One of these days I'll get to it since right now its just dangling in my trunk
joflewbyu2
08-18-2019 10:38 PM
ITSJESTER
17
12-06-2018 02:29 AM
