TSX: Replaced rear speaker, no Juice...weird
Hi all, I just replaced the rear 6x9 OEM speakers in my 04 TSX with a Pioneer TS-A6999 which I had from my previous car, the problem is that when I connect the speaker to the factory wiring there is no sound no matter how high the volume is. If i re-connect the OEM speakers, there is sound.
I tested for continuity from the end terminal to the speaker coil and everything seems fine.
If I connect the TS in another car they work perfectly, I thought that the range was the problem, but comparing the specs to the much recommended Alpine S, the TS-A are within the same numbers.
The specs for the TS-A6999 are:
- 240 Watts Max. Music Power (60 Watts Nominal)
- Sensitivity (Efficiency): 92dB (1W/1m)
- Frequency Response: 30 - 32,000Hz
- 4 Ohm Rated
AndrewS
19
03-14-2024 06:59 PM
mada51589
05-03-2022 08:54 PM
alan_rich
09-07-2015 11:08 PM
