Reinstall stock sub
Old 10-06-2003 | 02:19 PM
Question Reinstall stock sub
I previously had a amp with 2 subs in my trunck, but with the new baby I need to remove them. I've taken everything out with no problems, but I'm stuck on reintalling the stock rear sub. I had it removed since I was told it would sound better without this rear sub. It seems that the installer taped the line that goes to rear sub and connected it to my line converter. The problem I'm having is that I see four wires going to the line converter but only two connectors on the sub. Which ones do I connect to the sub?
I also seem to have misplaced the screws to hold the stock sub in place. Does anybody know what size I need and if I can just go to Loews or someplace and get them. Any help would be much appreciated
Old 10-07-2003 | 01:10 AM
drcookie's Avatar
I would suggest to take it back to the installer and tell them you want to put back your stock sub yourself and need some assistant on returning the wiring to the original manner. They should be able to point out to you easily.
Cheers !!!
Old 10-09-2003 | 08:37 PM
Ianbiz3's Avatar
basslink may work
hashbrown
02-18-2022 11:20 AM
vpasla1
09-17-2016 07:24 PM
DerrickW
11-15-2015 05:52 PM
rangomango
California
09-24-2015 05:47 PM
Quick Reply: Reinstall stock sub
