Radio
Radio
Changed battery and I went to the dealership to get radio code. they gave me my code, but it does not work. I also called acura customer support and they gave me the same code, but it does not work. any suggestions? i was thinking about just buying a new radio for my 98 cl, but the guy told me that is not a good idea to do that because it is a bose system and the sound will not sound good. He told me i had to buy new speakers and wires and all of that! i dont want to spend that much because of a stupid radio, is it a scam? should i just buy just a new unit? thanks... I Need advice
You certainly can change the head unit without changing all the speakers, wires and such. I just put in a Kenwood DDX-7019 yesterday in my 2006 MDX. I did use a level adapter to better match the levels of the Bose amp. Some people I know have not needed the adapter but I did. Without it, the sound was really distorted. But, needless to say, it can be done with no problems.
Hopefully uncald can chime in with a better explanation as he will actually make you a harness with or without the adapter.
Former Sponsor
Word?
Nvm!!
I went to best buy today to get a new radio and he was talking about $150 dollars to install it because of the bose system. Is there a cd player that is similar to the acura bose head unit, so i do not have to buy the pac oem2 etc.?
ഥഎണഡഏ Fellas Inc.
check ebay or check these forums to see if someones selling a used one. its really hard to believe that none of the codes you have worked -- could it be possible that the headunit that came with the VIN is not the same? Did they require you to read a serial number off of the back of the head unit?
I gave them the serial number that was on the radio. i dunno what could be wrong, i put the code in the right way, and when i can't do it anymore. i take the fuse out and try again.. i also disconnected the battery for a while, but still not working... they probably inputed the wrong code on their computer system.. what would you do then?
ഥഎണഡഏ Fellas Inc.
ask them to read it back to you...maybe 0/O got mixed up?
also try ownerlink -- i think there was somthing in here about recovering codes...IIRC
https://www.ahm-ownerlink.com/login.asp?brand=acura
Former Sponsor
Scru U guyz, Im Goin Home
Originally Posted by uncald4
That's bullshit bro. Installers get all petrified when they see BOSE. I know, I used to be that way. If you buy a deck.... send me the harness... I'll wire it up with the OEM-2 and Metra harness for $65 shipped. It would be a "plug and play" install for you, or your installer.
We used to get codes for customers for free and I remember getting a couple TL's that wouldn't accept the codes that were given from the SN. after calling the Dealership they advised bringing the car to a Acura service center for them to replace the radio free of charge. Now I have never heard of an official recall nor have i seen anything about it here on the forums but i do remember them saying this.
Also, and this may b a little obvious, but u know the radio will lock up if the code's entered incorrectly 3 times right?
dirleton
08-06-2024 08:19 PM
Puma Jim
20
10-20-2016 11:59 AM
SinCityTLX
20
10-19-2015 11:23 AM
jdmaszfcuk
10-19-2015 12:31 AM
