pulling a navi out
pulling a navi out
ok i got this guy that has two cars with the stock navi in it one is a 01 and the other one is a 02. he is giving me a steal on both the navi. the thing is i have to pull it out. what do i need to pull out and would i need anything extra to put it in my car?
what about the antenna?
No doubt you will need a new nav disc $185
Have you considered a TomTom gps?
Received 1,080 Likes
It's not as simple as just pulling a couple of wires. The wires for the navi are part of a larger harness. You'll need to pull the wires out of the harness plugs. Make sure you remove the pins that go into the harness plug.
doesnt sound cheap!
several hours of labor pulling harness wires and cutting them open in order to run them again in your car....
Hoping you have the security code for the radio...
verify the radio and nav do work and work with their security codes before you pull anything out
- disconnect battery power and the codes will be required
That security code is critical to have,,
dont forget the newest release of the nav disc, or your house wont be on it~
Stage 1 Audi S5
i installled a factory acura navi into a 1st Gen CL and it took some work but was really worth the outcome. Like the others have mentioned, you need the dash, a/c controls, screen, antenna, "brain" in trunk, dvd, trunk bracket, and the wiring. I can't imagine you get all the wiring so what I did was use pigtails that contained the plugs with a few inches of wire coming off. Then I went and bought shielded wire were needed and made my own harness. Lots of work but again, def worth it
Good luck
Good luck
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
