TL: Power Wire Help (Rear Amp Install)
i was wondering what hole through the fire wall you guys are sticking your power cable through? or are you guys drilling holes, if so where? i would greatly appreciate pictures, thanks in advance!
*2G - 2002 TL Type S*
I just cut a small slit in the rubber boot in the driver's area, seems to work fine. I ran 1/0 gauge through there with techflex on it, no problem. I can't show the power side directly but these might help in your adventure:
On the opposite side of the tunnel I ran my RCA's and my phone-jack type wire that runs my processor's subwoofer volume knob, all in techflex
But I recall the power wire work was pretty easy. Just pop your head under the steering column area, you should see a spot. I just used a piece of straight hanger from inside the engine bay area, and confirmed the grommet was clear to cut into. No issues that I can remember.
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
alan_rich
09-07-2015 11:08 PM
