Passenger side Door Speaker wires?
Hey guy's, just installed an amp for my aftermarket doorspeakers with two tweeter in the front. I have all of my rear speakers amped and my left driver side door. But the install dude said that he could not find the wires on the front passenger side door, so the front passenger door is not amped. Where are the wires?? Anyone else have this problem?? Is there a solution??
Thanks yall
Thanks yall
My baby's daddy
The solution is to get a competent install guy... the wires in the front passenger go through the rubber boot and to the speaker exactly like every other door. They attach at the wiring harness at to the radio, not sure which color, but they are standard honda harnesses.
It is not that hard to run new wires. If the wires are really missing( iow, the install guy cut and lost them somewhere) then run a new wire to that door. Just don't plan on ever putting stock back (not that you would but I like to install without butchering the factory wiring).
I assume your amp is in the trunk. Run the wire under the rear seat (take the lower seat out, one bolt on the driver side near the seat belt receiver) and then under the door sill moulding (just pull up and it will come off).
and then through the boot http://www.acura-tl.com/forums/showp...74&postcount=8
sockr1
10-01-2015 01:31 AM
alan_rich
09-07-2015 11:08 PM
