Parrot Ck3000 pre-installation question.
Professional SLACKER
Hey all, I'm trying to install the Parrot Ck3000 into my TSX. It seems to be more complicated than I thought it would be. I searched around the forum and I found that 1 person was successful with the installation but it was on the 03 TL-S. Here's the link:
https://acurazine.com/forums/showthread.php?t=78459
So what I'm going to do is purchase those wire harnesses (so I won't void my warranty) then connect them accordingly.
Here's my first question before I start destroying my car. Is the 20 pin connector on that 03 TL-S and the 04 TSX the same? configuration wise, perhaps color wise?
As soon I get started, I will post pics and steps that''ll hopefully useful for the forum.
Wish me luck
Wish me luck
VP Electricity
1 Post
I ahve not worked on the TL, but the TSX has a factory amp in the center console with two harnesses, an input harness and an output harness.
NEITHER harness is available in the aftermarket. The smaller 14-pin doesn't seem to have an analog at all, and the 20 pin is the same connector as the 2002-up Accord radio plug, but with more wires used. There is a thread going over this, but basically the 20-pin has R and L tweet, R and L F mid, R and L Rear mid, and L and R 6x9 woofer in it, so there are more wires.
If you want to make a "T" harness where you unplug the OE amp and plug in a bypass harness without cutting any wires, you can make your own "T" harness - just buy TWO radio-side 2002 Accord harnesses and TWO car-side Accord harnesses, and pull the wires out of one and insert them into the other (as I discuss in another post somewhere...)
When you pull the wires out of the connectors do not let the metal pin slash your hand/finger - it bleeds a lot.
alan_rich
09-07-2015 11:08 PM
