need wiring diagram
Well, I am adding some bass to my system in the form of 2 eclipse subs and a ppi amp. How should I go about running this amp?
AdamR |
Re: need wiring diagram
Originally posted by digitalgm Well, I am adding some bass to my system in the form of 2 eclipse subs and a ppi amp. How should I go about running this amp? AdamR |
I am having trouble finding out which wires need to go to the amp. Any help?
AdamR |
Originally posted by digitalgm I am having trouble finding out which wires need to go to the amp. Any help? AdamR if your amp has speaker level inputs, tap into the rear speakers to get the signal. if no speaker level inputs, you'll need a line out converter(LOC) but still tap into the rear speakers. for the remote turn on, you need to tap into the yellow/white wire on the bose amp. power should be from the battery with wire of 8 gauge, at least. better to run 4 gauge form the battery just incase you want to expand your system later. ground the sub amp to the chassis but clean the grounding point of paint first. |
