Need sound advice on upcoming install
I have a 5 channel SoundStream amp (Sound Stream amp pushes 60x4 and 110X1) that I'm having installed along with an aftermarket CD player (Nakamichi) and a 10" Soundstream amp in a sealed box.
Will I have any issues running the 4 stock door speakers off the amp (1 channel for each)? I do plan on replacing the door speakers, but can't at the moment. Has anyone used (or still use) their stock speakers with an aftermarket amp/HU?
This is for a 99 TL.
Thx,
B
Thx,
B
My other car is a DSM
your stock speakers are designed to handle about 25W RMS each. This setup will work, however i would recommend replacing the speakers asap. Do you have a bose system? if so, the speakers are likely 2ohm, which means youll be pulling closer to 100W per channel from your soundstream. check the impedance on the magnet of the speakers, or with a multimeter on the speaker wire connections.
Thanks for the info guys!
And yes, it is the Bose system.
Thanks fuzzy02cls - have always liked Nakamichi and the higher end audio equipment.
While were on the subject - can you give me a couple of choices of speakers that will fit with little or no modification required. I've seen a number of posts by people using Focal, Boston A, and Infinity. What models are they referring to?
Soul_Deamon
11-13-2018 04:44 PM
Joseph Stansbury
34
12-04-2015 01:57 PM
