Need Immediate Desperate help, Middle of install!!
I need immediate desperate help I am in the middle of a complete install!!
First
The 20 pin harness for the speakers that you pull out of the factory amp.
Does anyone know what wires are for the drivers side woofer?
Or even better if someone has a diagram stating what all the wires are on the 20 pin connector?
Second
Where is the best place to run the amp power wire from under the hood to inside the car? In othe
Third
where and how do you guys recommend doing the ground for the amp?
** I CANNOT THANK YOU GUYS ENOUGH FOR YOUR HELP I AM IN DESPERATE NEED **
First
Second
Third
run the power wire along the side of the engine bay and down in through the cabin through the stock wire grommet...then down along the passenger side underneath the carpet and away from all other wires (run all rca cables on the opposite side)
as for amp ground points, doesnt really matter as long as it's on the vehicle frame and sanded down to bare metal. I personally used the shock tower bolts in the trunk with crimps since it's already there. but you can always drill a new location anywhere and use a bolt with crimp to secure a ground.
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
