TL: Navigation Pixel Loss & Image Degeneration Help
Can I buy a new screen for this navigation? It's losing is pixels and sometimes is just white with a faint image if the controls in the A/C and GPS screens (all of them actually) when it's cold out and then warns up the screen is readable and see able. Is there a way to get a new LCD panel to swap out?
I drive a 2003 TL SType
9th Gear
There is a way to replace the screen. I had similar problems with my navi screen in my Acura Cl. I bought my used navi screen from a seller off of ebay and got directions on how to change out the navi on youtube. A little research and you should be just fine. :-) Oh almost forgot the navi screen was 150 so it's a lot cheaper than paying someone to fix it for you. I'm a female so you should have no problems :-) Good luck message me if you have any other questions.
Remember!
When Buying a used navi screen, make sure they give you the navigation code cause your original code wont be the same when you switch
I switched mines for 200 with the dvd system for 200
ITSJESTER
17
12-06-2018 02:29 AM
navtool.com
31
11-16-2015 08:30 PM
