my new soundsystem
my new soundsystem
hey guys i just installed my system and i got a line out converter but the remote turn on switch isn't working so i just tapped into the back two speakers and connected it through that way. I'm also getting some feedback after i turn off hte car. Does anyone know wat that's from? cuz my amp is on all the time until i pull the ground because the remote turn on doesn't work sooooo i'm thinking its from the fact that the amp is always on......ne advice would be welcome thanks!
i tap mine on the stock amp in the trunk. Its one of the yellow wire, only 2 yellow wires in the plug, 1 is power and the other is remote, i forgot which position its in. But if you locate the stock amp, test it with test light. Its cleaner this way than run wire all the way to the front fuse box
Reach
05-19-2006 11:56 AM
