mp3 changer
Retired. Not available.
You can add an Alpine changer using an adapter available at www.autotoys.com. Forget the FM modulator crap. I have a Sony mp3 changer with FM modulator built-in. I got so frustrated with the sound quality that I disassemble the unit and use unmodulated signal.
I was looking into doing this myself and just throwing in 6 mp3 CDs and using shuffle play. How does song navigation work if you hook up the Alpine CHA-S634 to the stock head unit? Change disc# and track# by using 1-6 and seek? Random button? And don't you technically need 2 adapters? Stock headunit -> M-bus adapter -> AI-net adapter -> CHA-S634?
I'm not sure which adapter it was but there is only one needed. I check it out for you guys if you want too.
MisterMeoff, you need to clear out your PM box. Select "from the beginning" and delete things from your "Inbox" and "Sent Items"
You would have to select "from the beginning".
go here and take a look at the botoom of the page, under your sn to see how many messages you have.
http://www.acura-cl.com/forums/index.php?s=
If He Dies...He Dies
I just deleted all the sent items. I'm good to go.
Brian, you have a 2nd gen CL? If you do what exactly did you do to get it to work?
MY factory HU is acting up. some lady tried to make a quick left in front me while i'm traveling straight. So I slam on the brakes and my water tumbles forward and splashes onto the HU. I was praying that it was ok. Like 3 hours later while playing a cd, it starts spitting out cds. Then I put the car in park, it started spitting them out again.
I don't even want to take it to the dealer. I would rather get an aftermarket HU and call it a day.
I have most of my music burnt to MP3 cds. It wouldn't make sense for me to buy a $300 piece of equipment to download again all my MP3 cds to. I would rather just buy an aftermarket hu and mp3 cd changer and call it a day.
i have the alpine 6-cd mp3 changer, works beautifully
edit: posted right as you did above. still need someone who's using it with their stock headunit that can help out.
Dont know how it is operated but this is the info from my friend who has it in his 2002 TL.
http://www.acura-cl.com/forums/showt...19#post1463319
I talked to a service tech @ an Acura dealer and he said the 2nd Gen CL factory HU has no aux output on the back to add another component such as a cd changer.
Got da Internet Goin Nutz
I know, I've done it!
Its called a blitzsafe adaptor. Find Streeteffectz on this site and order one from him. Well worth the money and cheap too! After the simple plug and play install you will have a set of RCAs that you can plug anything into. To access them you just press the CD button twice.
oh ok. I have to get my factory HU checked out on Tuesday because water splashed on it the other day.
I think I will check it out.
autotoys.com sells an alpine based 6 disc MP3 changer that works with most 98-up honda/acura vehicles, including the CL. It plugs directly into the changer port on the back of the OEM headunit. The downfalls of this are you can only play 99 songs per disc and there will not be any titles or folders because of the limitations of the oem headunit.
A CHA-S634 will NOT work with the OEM deck... that changer works on the Ai-net protocol and cannot be controlled by an M-bus unit.
Another option is JVC has a universal MP3 changer that uses a seperate display. You would then want the auxillary input adapter to get a clean signal into the deck. Autotoys.com also has those adapters.
Originally posted by SumAccordGuy94
... A CHA-S634 will NOT work with the OEM deck... that changer works on the Ai-net protocol and cannot be controlled by an M-bus unit.
ivegotthenav
09-11-2015 07:51 PM
Black_Pride
28
12-12-2004 01:06 AM
