Looking for a TSX pocket DIN adapter
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
I recently came across a great deal on a Sirius Starmate DIN installation kit, so I grabbed it. It is essentially a DIN panel that the radio snaps into:
The results are VERY clean. I have it in the center "pocket" or CD cubby, but it doesn't fit completely inside, so the door doesn't shut. I thought about cutting it down with a Dremel, but that can only lead to tears![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Does anyone off a single DIN adapter or kit that replaces the actual cubby and door mechanism? I know that Acura makes an install kit for their MP3-CD and cassette modules, but are these single DIN units?
If none are commercially available, are there any custom installers that will make me one?
Thanks!
Todd
![](http://www.tss-radio.com/images/Sirius_STV2_Starmate_Replay.jpg)
Thanks!
Todd
You can purchase the OEM pocket-to-single DIN adapter for the Acura MP3CD player seperatly for approx $70. It is a standard single DIN socket and would work for what you're asking. I do not have the part number for it, hopefully someone else can jump in and point it out.
I have seen it in person though. Its not a perfect fit, as it juts out a little bit, but it is sadly the best thing available for a TSX pocket replacement without getting a custom job done.
I've seen your existing pic and I think it looks better than anything that DIN unit will offer you.
![](http://www.toddjkelly.com/tsx/sat_install3.jpg)
You should consider drilling a hole and routing those wires around the back of the unit and hardwiring them, so they look more like this:
![](https://home.comcast.net/~writemike/stereo/sirius1.jpg)
Of course, the best installs I've seen are the ashtray ones... ie:
![](https://temp.corvetteforum.net/c3/tshort//Temp/xm_in_dash.jpg)
I actually did route the wires through the back and up under the console. They end up in the armrest. I never took new pics ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
I'll think about the cubby unit - if it's not perfect, maybe I'll pass.
Thanks for the code, DiaBando!
Todd
Todd
mlody
12-04-2019 02:11 PM
