Koda 10 in the stock sub location
check this out http://www.adireaudio.com/
this has been mentioned before in the forums, but I had a chance to hear a shiva and its niiice, what do you think of trying the koda 10 in the stock sub location
the koda 10 supports IB applications, I know you have to mod the trunk lifter thingy, what do you guys think?
Param
10"
Fs 28 Hz
Qms 3.5
Qes 0.42
Qts 0.40
Vas 85 liters
Znom1 4 Ohm
Re2 2.8 Ohms
Le3 1.3 mH
BL 10.2
Sd 344 cm2
Xmax 18mm one way linear
Pmax4 300W RMS, 600W peak
NOTE: Power rating is thermal only! It is NOT a power requirement; typically you get full output with significantly less power than the rating.
SPL5 88 @ 1W
Diameter 10.5"
Cutout 9.25"
Depth 4.75"
Volume 0.08 cubic feet
Weight 17 pounds
Price $229
Param
10"
Fs 28 Hz
Qms 3.5
Qes 0.42
Qts 0.40
Vas 85 liters
Znom1 4 Ohm
Re2 2.8 Ohms
Le3 1.3 mH
BL 10.2
Sd 344 cm2
SPL5 88 @ 1W
Diameter 10.5"
Cutout 9.25"
Depth 4.75"
Weight 17 pounds
Price $229
mrkingstonvi
02-22-2016 01:53 PM
handsom-hustla
11-13-2015 05:04 PM
