Kenwood Excelon DDX7015
Chloe @ 17mo
Originally Posted by UNCTYPE-S
not too sure cause i have a CL, but thats getting installed in my car this weekend.
It will fit but, you are going to need a custom trim ring to surround it. Otherwise, you will have huge gaps all the way around the unit. You could possibly modify one of the single Din kits to work as basically a faceplate as well.
Chloe @ 17mo
That would depend on how fancy you wanted. Someone could probably cut a piece of plexi and paint it and be done with it. Or you could have a custom fiberglass piece made that fits perfect and looks stock.
Personally, I have wondered if you could bolt the double din unit to the factory brackets and take the Metra kit and use a dremel and cut the opening until it just slips over the double din. Basically, the Metra kit would just be used as a trim ring.
Chloe @ 17mo
Above n Beyond
i have a pic of another cl owner that did it into his cl premium. looks pretty good. mind should look similar, but im in the process of finding out what the stock cd player faceplate is made out of so i can replace it with the new stuff and look stock.
how can i host this pic?
Sig Rho's Finest
i was very close to getting that unit, but i decided to get a cheaper unit. its GREAT. ur gonna need a custom trim. i bought mine from shawhite, he made one out of fiberglass that matches the wood trim. looks nice.
Chloe @ 17mo
Pegon95
09-15-2015 01:54 PM
6spdCL-S
07-18-2009 08:02 AM
