Kenwood DDX8017 on the way
#41
The two mounting blocks I provided must be in on the wrong side - one way they are 3/4" and the other way they are 5/8" thick - they need to be on the 5/8" side - I've installed 12 of these with that EXACT kit with PERFECT fitment. And you need to adjust the headunit to the left with some kind of washers or something. The kit is made to fit perfectly - I can see from the pics the unit is to the right and tiliting down to the right - the unit needs to be adjusted around it itself, not the other way around:
Same kit, same unit, same mounts
#42
Audio Enthusiast
Originally Posted by StreetEffectz
The two mounting blocks I provided must be in on the wrong side - one way they are 3/4" and the other way they are 5/8" thick - they need to be on the 5/8" side - I've installed 12 of these with that EXACT kit with PERFECT fitment. And you need to adjust the headunit to the left with some kind of washers or something. The kit is made to fit perfectly - the unit needs to be adjusted around it itself, not the other way around:
#43
Ohhhhh, that could be the problem - PM me your address and I'll send them right out, unless you want to make them yourself - they epoxy right to the factory mounting cage and to the back of the trim piece.
#44
Audio Enthusiast
#46
Quick question about the DVD
Couple of quick questions about your new toy. How is the quality of the screen when playing DVD's? Second, can you play DVD's while driving? I know older models of in dash DVD's you could bypass the cutoff feature by grounding the parking brake wire. However, some of the newer pioneers and eclipse, use a gyroscope that can sense when the vehicle is moving, making the DVD player unavailable while the vehicle is moving. Just wondering if the Kenwood is like this?
Thanks, Lucas
Thanks, Lucas
#49
Audio Enthusiast
Thanks, Lucas
Thanks, Lucas
#50
i have similiar problem with my 7017 and the left side gap, althought mine is not as apparent as yours, and it is an easy fix, just needs to be played around with a bit. the only thing that disappoints me with the 7017 is that there are no images or visualizations, its a very boring unit when it comes down to it. althought it does come packed with features. not sure which outweights the other.
#51
Originally Posted by NiteQwill
Nice HU, it's nice upgrade I think from Kenwoods 7015....
Here is my kit Ron made more me, structured around the Metra kit...
Pegon95
09-15-2015 01:54 PM
