Keep factory headunit?
Hi I'm pretty new to this site. I am installing 2 10" JL w0's and Boston Pro components in the front. I have 2 MTX amps to run them. I was just curious if anyone has left in thier factory radio, cause its pretty cool to have the in-dash changer. Also I wanted to know if anyone things it will sound like crap if I leave it in. Thanks!
I totally DISAGREE!!!
I have a NAVI CL-S, and for obvious reasons (the NAVI "voice" and the steering wheel-mounted audio controls), I kept the OEM head unit (made for Acura by Alpine) when I got rid of ALL of the Blowz low-fi components.
I've been into audio longer than many of you posters have been on this planet, and, believe me, my "modest" upgraded system (see below) was such a HUGE improvement over the Blowz system that it's hard to justify the hassle, expense and INCONVENIENCE of giving up the Alpine OEM head unit. IMO, it sounds pretty damn fine to me.
HOWEVER, If you DON'T have a CL with NAVI, and/or you're willing to give up the really nice OEM features Acura/Alpine have provided you with their integrated head unit, then, obviously a new high-QUALITY head unit probably is going to give you more clarity (less distortion), etc. if your ears are sophisticated enough to hear it.
So, non-NAVI folks, in the final analysis, you gotta ask yourself, "Is it really worth the extra bucks?" BTW, If you do go to a new head unit, a subwoofer level control is a mighty nice feature.
[ 08-13-2001: Message edited by: technoid ]
I agree with technoid. I don't have the Nav system. I replaced all of my speakers and added a sub (see sig.) and the system sounds great. I had an Eclipse head unit in my old car(for sale, if anyone wants an Eclipse CD unit), and I'd say this upgrade sounds at least as good.
There were three big reasons I didn't want to replace the stock head unit. The first reason is that I wanted a stealthy look to my system so theives wouldn't be too tempted... and what's more low-key than stock?
The second reason I kept the stock H.U. is that I didn't want to go through the pain of getting into the dash, since I did the installation myself.
The third reason is that I have seen many pictures of aftermarket H.U.'s installed in the CL and not one of them looked right to me. The rectangular aftermarket units just don't look right in the CL's trapezoidal dash location.
You could do what I planned to do. You could install the system, keeping the stock head unit, then if you don't like it, put in a new one.
I spliced into the signal wire rather than use a line-level converter. I felt this was the cleanest way to do it. If you do this, be sure to use a groud-loop isolator to eliminate any background noise.
Retired. Not available.
Originally posted by technoid:
<STRONG>I totally DISAGREE!!!
2001 3.2 CL-S
NAVI
Satin Silver
Comptech Headers,
H&R OE Sport Springs,
Koni Yellows,
Comptech Anti-sways,
Neuspeed Upper Strut Tie Bar
JL Audio 300/4, 250/1 monoblock,
JL Audio 10W6 sub in custom enclosure,
Boston Acoustics ProSeries 6.5's,
Boston Acoustics RM9's
[ 08-08-2001: Message edited by: technoid ]</STRONG>
2001 3.2 CL-S
NAVI
Satin Silver
Comptech Headers,
Koni Yellows,
Originally posted by SilverKnight:
<STRONG>
Ummm ... Are you sure the head unit is made by Alpine? I know the Navi is made by Alpine but the head unit has Bose stamped all over it. I really doubt it was made by Alpine.</STRONG>
<STRONG>
You can also do what I am going to do and that is keep the stock headunti and tap into the signal befor it gets to the boes amp and run it to an audiocontrol four.1 EQ. This will also boost the volts (that are extreamly low from the head unit) as high as 13v depending what you amp can take as far as input volts. I think this will give you the cleanest and most powerful signal from the HU. I am going to install it right abouve the HU in that usless coin tray (for non navi). hear is a pic of the EQ
Blowz head unit? NOT!
The installer gurus at Myer-Emco (the premier audio/video company in the Washington D.C. Metro area), told me that the head unit is made by Alpine -- period. (The NAVI unit definitely is an Alpine - ask Radley Acura.)
BTW, in my installation, Myer-Emco used the OEM head unit, without hacking it to pieces, and spliced into the high-level output cables to the former Blowz power amp. There is NO "low-level" signal output from our Alpine head unit for a device like your AudioControl EQ, which, unless it has high-level to low-level conversion capability, could introduce unwanted distortion, etc. if inserted between the OEM head unit and a power amp.
As far as MY installation, there was NO need to boost any voltage--I got plenty-o-gain. In fact, I am inserting a subwoofer attenuator between my OEM head unit and the 250/1 monoblock sub amp. So, given that my JL Audio 300/4 amp has both low-pass and high-pass filtering, so why hack up my dash any more for an aftermarket EQ?
I thought that I have seen some people say that you can tap into the signal before the blowz amp from the HU and get a cleaner signal but its weaker than if you tap into it after the blowz amp....so the AC EQ would kick up the volts to compensate for the lower signal. Am I wrong in thinking that????? Can anyone clear this up for me????
OK, here's what happened to me:
I haven't got a EE degree (I'm just a humble systems analyst), but I do know (fer sure) that my installers ripped out the Blowz amp completely and "spliced" directly into the cables coming out of the head unit--period. So, you're partially correct: No BLOWZ amp, no distortion. The audio cables from my head unit were connected directly into my JL audio amps, which have variable line-input level adjustments. No special in-line mods were required, as there was more than enough voltage to drive my JL Audio amps.
That's my story and I'm stickin' to it.
<STRONG>Blowz head unit? NOT!
As far as MY installation, there was NO need to boost any voltage--I got plenty-o-gain. In fact, I am inserting a subwoofer attenuator between my OEM head unit and the 250/1 monoblock sub amp. So, given that my JL Audio 300/4 amp has both low-pass and high-pass filtering, so why hack up my dash any more for an aftermarket EQ? </STRONG>
f-a-b-o-l-o-u-s
fvck the stock 6cd changer!
Get a cd/mp3 deck, and you'll never have to fumble around with cds again.
I just got the JVC Digifine 2.1, 3 4v pre-outs, 50w x 4 internal, multicolor disp, cd/mp3 text, motorized aluminum face for around $300.
rcs86
08-02-2016 06:52 PM
