I've been bit by the Car Audio bug again...
Old Aug 23, 2003 | 03:13 PM
mrsteve's Avatar
I used to have a system in my Explorer...went away to college, sold the Explorer and kept the most expenisve parts of the system (amps, sub)...
I wanna do an install in my CL.
Basically it will be a 2 amp set up, 1 12" sub, keep the stock head unit, and replace the stock speakers and run them off of my 2nd amp. I don't need advice on what speakers to get, but I do need installation ideas.
I have equipment in my trunk all the time for work, so my space is limited...enough for 1 12" sub...so where do I mount my amps?? On the back of the seats? Also...what is the easiest way to wire an amp up using the factory speaker wiring and the easiest way to get a wire to the battery and a remote turn-on wire.
I tried a search but got bored with it...if someone could post a link that would be cool too.
Old Aug 23, 2003 | 05:01 PM
Nicky Pass's Avatar
Fuct in the hed!
1 10W7, JL XR 650CSi's in front....690CXi's in the rear....JL 500/1 and 300/4 amps.
Old Aug 23, 2003 | 05:58 PM
Six Shifter's Avatar
an adult perspective
basically same set-up as Nicky's, except also using JL components in the rear shelf and sub fires forward into the cabin ... no rattles from the spoiler
Old Aug 23, 2003 | 06:29 PM
mrsteve's Avatar
Nice installs, but I can't go that big of a box...I need the room...I have a single 12" box and then I need to mount the amps somewhere.
Old Aug 23, 2003 | 07:40 PM
mcdanjw's Avatar
I mounted my Epicenter, 3xs, and amp (on the other side in picture) all on the sides of my speaker box.
Not the most beautiful install, but it works for conserving space.
Old Aug 23, 2003 | 07:44 PM
mrsteve's Avatar
I believe that mounting amps directly to the sub box will eventually damage the amp due to extreme vibrations. Can you mount amps to the back of the seats?
Old Aug 23, 2003 | 09:29 PM
SilverKnight's Avatar
Retired. Not available.
Did you read the sticky in this forum? You dont even need to search.
Old Aug 24, 2003 | 02:30 PM
dets's Avatar
2004 Euro Cup Champions
damn silverknight, i was just about to say that......
Old Aug 24, 2003 | 03:35 PM
BoostedM3's Avatar
Bagged hybrid
You can mount the amps where the spare tire is...if you can live without the spare.
Old Aug 24, 2003 | 08:02 PM
fyud's Avatar
i have my 2 jl audio amps mounted on 3/4" mdf approx 12" x 24". i then bolted the board to the back seat frame. it is very solid.
Old Aug 25, 2003 | 03:40 PM
mrsteve's Avatar
Now that's the type of idea i'm looking for. Did you put carpet on the MDF? Anybody know where I could get a few square feet of carpet to match?
Old Aug 25, 2003 | 11:13 PM
www.selectproducts.com
Old Aug 26, 2003 | 08:42 PM
sonor kid's Avatar
One who Laps
I did the same thing, I had tweeter make the board and mount the amps to the back of the trunk. They also built a cutom box for my two 10's and covered everything in matching carpet for $250.00, well worth it.
Old Aug 26, 2003 | 08:56 PM
mrsteve's Avatar
I think I'll go to Home Deopt and buy some MDF, throw a little carpet on there, and then take it to a shop to have them install it. I just don't feel like taking apart an Acura and worrying about putting it all back together. I figure installing 2 amps can't cost me more than $100.
foxriderar77
Nov 19, 2020 10:17 AM
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
vanderveen44
ILX
Sep 2, 2015 01:48 PM
