Installing indash tv/dvd
Old Nov 18, 2004 | 06:20 PM
REDLINEN's Avatar
Missing my Acura's
Im going to be getting a indash tv/dvd player installed in my 2000tl I was wondering how easy is this what im going to need and what i should pay parts,labor and etc. any help with these questions would be greatly appriciated thanks in advace.
p.s. it is a KENWOOD EXCELON KVT-815DVD
Old Nov 21, 2004 | 02:22 AM
REDLINEN's Avatar
Missing my Acura's
anyone?
Old Nov 21, 2004 | 06:34 AM
JnC's Avatar
JnC
Former Sponsor
Hwy sup red, first off that Kenwood is a great piece of equipment. You would need a metra single dash kit for ur TL, part number 99-7892
Old Nov 21, 2004 | 09:31 AM
Scott P's Avatar
Mobile Elec. Guru
actually the kit is 99-7868 if memory serves me correctly. the one above is for a first generation TL. as far as installing it I'm not sure about in MA, but here in memphis average going rate to install indash dvd/screen is about 100-150 including parts. it's not to hard if you know what you are doing or have a competant installer.
Old Nov 21, 2004 | 11:40 AM
Toby_TL's Avatar
I just got mine KENWOOD EXCELON KVT-815DVD installed lastweek...first i tried to do myself and end up screw couple thing so I let the shop installed professional done for me for $55..I think that is good price including metra kit to
Old Nov 22, 2004 | 11:34 AM
REDLINEN's Avatar
Missing my Acura's
Thanks for the input! i got quoted 200$ by tweeters they said something about intergrating the factory system. and did I get a good deal I got the unit for around 850$ brandnew?
Old Nov 22, 2004 | 11:43 AM
Jput's Avatar
850 is not bad as far as installing it that seems pricey though $200 i should be upping my prices in that case lol. I usually do it for below 100 depending on the application.
Old Nov 22, 2004 | 01:05 PM
NaturalTLS's Avatar
Great headunit, I have the 915dvd and am very happy with it. I payed about 200 for the install of my all in one as well, they even had to charge me more becuase they had to route and install the antenae for the tv tuner. If you havent installed a headunit before, I would def recomend having professionals install it, there are a ton of wires. You will only need the wiring harness and a dash kit to use your factory speakers, however you will lose you factory sub. Since you are upgrading your headunit, do you have plans to upgrade your factory speakers?
Old Nov 24, 2004 | 07:35 AM
AcuraX2's Avatar
If all you are doing is swapping the factory head for the Kenwood, $200 sounds high to me for labor only. If it included the kit, harness and any wiring, that would be better but, still high. If you mount the brain under the passenger seat, it can all be done in 2-3 hours. I know because, I have done it three times in my own 2000TL. I would think between $100-150 would be better and at $150, they should provide the kit and harness. As for integrating the factory system, if they plan on keeping the factory sub and the steering wheel controls, then $200 may not be enough. That is alot different than just swapping the head unit.
Old Nov 30, 2004 | 10:17 AM
Go Stros!
Is there a way I can wire up my screen/dvd player and still use my factory sub or am I going to have to deal with losing it and getting aftermarket subs for bass.
Old Dec 1, 2004 | 02:01 PM
REDLINEN's Avatar
Missing my Acura's
The factory sub has been disconnected for a long time! lol!
Old Dec 1, 2004 | 03:02 PM
Go Stros!
well Is there a way though? I mean I like the factory speakers and sub but I know the speakers sound like crap without the sub. I just wanted to keep the sub until I have more money to put a system. I mean eventually I'll put in a system, but money wise I won't have enough for the setup I want for a while, so until then I'll have the screen but only the four door speakers? I don't know just wondering if I could keep the factory sub and still use it with an aftermarket Indash dvd/screen.
Old Dec 1, 2004 | 06:24 PM
fsttyms1's Avatar
its 99-7868
and to hook up the factory sub with a aftermarket HU, get a small amp and hook it up to that. it will sound alot better with better and more power going to it anyway
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
pistacio
Sep 26, 2015 09:45 AM
TxRzrBk
Sep 17, 2015 01:07 PM
