installing amp and sub on 99 tl
I just got a 99 TL preimium with navi. I uninstalled my old amp and sub from a 2000 acura integra (which had aftermarket cd deck), and was wondering if the install was as easy on the TL with STOCK cd deck. Is there a link to an installation instruction on this?
thanks in advance
thanks in advance
El Presidente
there is a detailed post about it, i think its in the sticky section up top. But basically what you want to do is run the power from the battery and what not like normal . Then, you would need to find which wire from the stock amp (located behind the rear passenger-side seat) to tap for the remote wire and then hook up a line out converter and then run the RCA's to ur amp.
AndrewS
19
03-14-2024 06:59 PM
Pegon95
09-15-2015 01:54 PM
