Install ?
Install ?
This weekend i'm gonna install a 5 channel Alpine amp and Boston Acoustics pros 6.5 inch seperates. And 6.5 coax in the rear door's. I'm gonna use soundgate converter's so I can keep the factory H/U. My question is, do I still need to bypass the factory EQ, In this type of install?
Boomer SOONER
no I believe the only reason you need to bypass the internal EQ is if you are using new speakers with the stock HU and amps...so you should be all good, I hope that amp has lots of juice cause those Bostons need it -especially the components.
Yes, you absolutely have to bypass the eq in an install such as this. Its not difficult to do since its already been figured out by a few people on this board. Unfortunately, most of the info is unavalible since the board was updated, but luckily I found a wiring diagram on my computer. Have a look at the pic below. You need to tap these three wires together..
Let me know if you have anymore questions..
Do you need to bypass the EQ if you are just hooking up a sub amp? If not, can I use the wires at the back of the car near the amp? And are they line level, or do I need to use a LOC?
BLU/GRN +
ORN/BLU -
Schematics
Good luck
Iggy
I tried to hook some RCAs to the wires you mentioned above, and I can't seem to get any output from the AMP. I checked the amp with another input (CD player) and it worked fine. Is there something I don't konw?? I am using an RF 501BD amp, and nothing is coming out!!
HELP!! :
HELP!! :
Please Help!!!
I just took the 97 tl to "Jerk It Silly". They installed my Infinity Kappa 10 in a ported box and my Pioneer Class D 1000w amp. The sub is run at 2 ohm. The amp at 2 ohm pushes 600 w max. I have an LOC coming out of the one of the Polk690's in the rear dash. out of the LOC there are rca's into the amp. Power is run, remote and ground are connected. Fuse is in.
IT makes very little sound if any. And when it is audible it sounds very muffled. All the equipment is new. Have I (they) done something incorrectly
:ar15: Circuit City.
Originally Posted by AcuraX2
Hehe, you an me both. I actually tried to use the factory head and ended up with "screw it, rip it out". We Okies got to stick together.
Anyway, yes, you do need to bypass the EQ if you don't want the treble boosted (for mains) or part of the bass missing (for subs).
You can pull the preamp signal from the small black harness, or just feed it back in if you want to use speaker-level converters. (I'd go with the first).
Most of the threads for doing this are linked to from the sticky thread "comprehensive data..." at the top.
I got less bass when I was using my LOC at the preamp signal. Once I wired the LOC to the wires going into the rear sub, I got more bass, except when I turned my volume up past halfway, then bass was pretty much gone. I also did the eq bypass, but I noticed that on the B4-B8 wire cut, the B8 wire looked black to me, not blue, could I have done this wrong, and ahve it affecting my aftermarket sub output?
cycdaniel
12-17-2019 10:58 AM
pistacio
09-26-2015 09:45 AM
