impedance question
impedance question
For you audio/electronics gurus, I have a question. I'm pretty sure of the answer but am not positive. Here's my info. I have four, four ohm speakers. If I run them all in series to the same channel on an amp, the amp will still be only at four ohms, correct? What if I ran two of them in series, and the other in series as well, but then ran each pair with one another in parallel to the same channel on the amp, would that equal two ohms? I'm pretty positive but just want to make sure.
Thanks in advance!
Thanks in advance!
Originally posted by Lung Fu Mo Shi
Series = R + R + R + R = 4R
Parallel = 1 / (1/R + 1/R + 1/R + 1/R) = R/4
The other method as you described = 1/ (1/ (R + R) + 1/ (R + R)) = R
Registered AssHat
Basically, if you put four 4 Ohm speakers in series on one channel, you'll have 16 Ohms (4*R). If you put them all in parrallel, you'd have 1 Ohms (R/4). If you did it the way you mentioned, you'd still end up with 4 Ohms.
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
