How to remove Stock head unit...
I need to remove a stock head unit in a 1998 3.2 Acura TL, can you guys please put up some directions or instructions, pictures would be beautiful.
Thanks in advance
Thanks in advance
You're starting to piss me off.
Received 2,329 Likes
I can tell you..
Get a flathead screwdriver and a phillips
Use the flathead with a piece of thin cloth over it, to pry the fake plastic wood on the dash. It is held on with plastic clips. I usually start at the far right above the glovebox. Take that all off, this will also include the climate control unit. It has two wiring harnesses, you have to pinch the harnesses on the top and bottom for them to come out.
Now for the radio itself, you'll see 4 phillips screws exposed. Unscrew them. There will be a bracket that attaches itself to the radio. Undo that too. There should be two harnesses for the radio and the antenna.
If you have any other questions ask away.
cycdaniel
12-17-2019 10:58 AM
Joseph Stansbury
34
12-04-2015 01:57 PM
detailersdomain
Wash & Wax
09-03-2015 10:56 PM
