HOW MANY OHMS IS THE STOCK SUB and watts
I was just wondering how many ohms the stock sub is and also how many watts because I want to upgrade that next. And lastly were is the stock amp located if there is one. Thanxs for the help
16yrold/w2k3/3.2tl:cool: |
I'm not sure about the wattage or ohms, but the location of that amp is on the bottom side of the rear shelf on the right side (as you're looking in the trunk).
It's a small black box with cooling slots. |
Well if you had done a search you would have found that someone already posted that the stock sub is 1/2 ohm and powered by a 100W amp. :D
Yep,
1/2 ohm 100w. Fla-Tls, Not sure what car you have but you can't see the amp from the trunk. You are looking at the window antenna coil. The sub amp on 99-2003 TL is located behind the rear seat bench in the area of the rear right strut tower and it is silver. To get to it requires pulling the bottom rear seat and the rear back rest. 2k3tl, Not sure what your deal is, and don't get me wrong, I think it's great you have such a nice vehicle at 16 but from an older guy who's first car was a '73 Buick Lesabre you could be a little less Austentacious(look it up). BTW, where in cheese land are you? I grew up in Edgerton which is exactly between Janesville and Madison. I went to college in both Platteville and also Menominee. Cheers, Iggy |
You are so right Iggy, My first car was a USED 63 Chevy bel-air. followed by a 50HP '66 VW bug!
I hate to be jealous of today's youth... rather I would like to be happy for them... but as you say, it doesn't need to be rubbed into our faces... Just remember, YOUR WORK RIDE, is MILES ABOVE any TLS, BIMMER, or BENZ!!! Thanks for your help in talking down zotl, and helping out Taestee... Phew! I hope zotl recovered from his disaster??? Have a great 4th! Southy:cool: |
Originally posted by Iggy Fla-Tls, Not sure what car you have but you can't see the amp from the trunk. You are looking at the window antenna coil. The sub amp on 99-2003 TL is located behind the rear seat bench in the area of the rear right strut tower and it is silver. To get to it requires pulling the bottom rear seat and the rear back rest. Iggy :cry: |
