Help!!! Map light, Homelink, and Dome light DON'T work
i was trying to wire a neon light to the dome light in the middle of the car. I added two wires, one to negative and one to positive and i accidentally touch both ends of the wire together and my map light, homelink , and dome light don't work. HELP!!! does anyone know how i can fix this? did i over load it? blew a fuse? someone plese help me.
Received 1,080 Likes
Check fuse #11. It's located on the passenger side. Open up the passenger door and remove the plastic cover that is on the side of the dash.
I think that's your culprit. Did you notice that your trunk light and driver's door light doesn't work either? They all run off that fuse.
Good luck,
Neil
Good luck,
Neil
ranger29 (01-04-2020)
mada51589
05-03-2022 08:54 PM
drewdeezy03
09-03-2015 08:04 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
