grounding the hu
grounding the hu
i need to hook up the ground for my hu, i found this bolt that's grounded behind where the hu sits (its already got a bunch of shit connected to it) but when i try n loosen it, it doesn't budge at all. anyone got any suggestions on how to loosen this bolt, or any other good place i can connect my ground? its 2nd gen tl-s.
Swift 3 B-A-N-G-E-R
![Ponder](https://acurazine.com/forums/images/smilies/ponder.gif)
Mobile Elec. Guru
Lord Ubber
I have a Alpine and they recommend a ground bolt rather then the harness ground.
The way to know if the bolt is grounded it to buy a ground tester at WalMart or a auto store(5-10$).
It's nothing complicated. It looks just like a ice pick with a wire and a roach clip attached.
You attach the roach clip to the bolt and then you touch the red (power) wire with the ice pick and
if the light at the end of the pick lights up. It is grounded.
Swift 3 B-A-N-G-E-R
Originally Posted by Scott P
actually what he is doing is trying to give the radio a better ground. It is a common misconception that doing so would help to alleaviate alternater whine. Unfortunately this is akin to putting a band aid on a bullet wound. If you have a set up that is so succeptible to picking up egiune noise that the only resort left to try and fix it is to reground the radio, then the problem lies in the equipment not the ground location. Furthermore it is more than likely the bolt in question is where the factory ground location for the radio's harness.
emailnatec
29
09-28-2018 04:27 PM
Acura604
20
08-05-2017 12:55 AM
