Finally: completed the audio system, with balun info
Old 08-12-2007, 10:14 PM
  #41
Reach's Avatar
Yes, those alpines will fit.
Old 08-13-2007, 04:22 AM
  #42
BiG1CeS's Avatar
DATS DOPE!
OKAY YAEH I GOT A 2004 TSX with NAV AND I GOT A 1000 Watt DUAL AMP AND A 800 WATT KIKER!
I WENT AND BOUGHT THE AMP KIT AND I JUST WANT THAT! THE SIDE PANEL SPEAKERS ARE FINE!
IS THIS AN EASY TASK TO DO OR WAT?
Old 08-20-2007, 11:59 AM
  #43
carbonatd's Avatar
I was under the impression JL made a device that converted line level outs like the TSX uses to a usable RCA signal? Would it not be possible just to use that $80 device? I am still looking for the part number
Old 01-10-2008, 11:13 PM
  #44
Need more room in
wong05tsx's Avatar
Originally Posted by Reach
allowing an extremely short 2ft unbalanced cable run to the amp, thus picking up a negligable amount of interference along the way. I used high quality shielded directional interconnect cables to aid the short run as much as possible.
Waiting for Mercman to finish his balun, last thing until my new install. I noticed you ran a unbalanced cable from the balun to the amps. I ended up ordering a 4ch balanced rca [ http://www.knukonceptz.com/productDe...prodID=KRY4.4M ] . Would the balanced rca's work fine? since the balun is supposed to convert to a unbalanced signal and i'd be running Bal. RCA -> Balun (now unbalanced) -> Bal. RCA's
If you're wondering what the new setup was:
Current:
JL 500/1
JL 300/2
Hertz HSK165 Component front
Polk DB650 coax rear
rear 6x9 removed
Dynamat xtreme'd front doors
Image dynamics 15" IDQ dual 2
Mercman's magical harness
4ga Rockford run to back
New:
Sundown SAZ-1500D (800 + (10% underrated) x1 @ 2ohm)
Sundown SAX-100.4 (brg to fronts, 320x2 (+10%) @ 4ohms)
Sundown SAX-100.2 (rears, 100 x 2 (+10%) @ 4ohm)
Hertz HSK 165 Comp fronts
Alpine Type-X SPX-177A Mids only
Treo SSI 15" Dual 4
Mercmans magical harness & balun (last thing waiting for!!)
0ga kicker hyperflex run
[new battery if i get any dimming]
stay tuned for a thread with pixors
Old 03-25-2010, 04:37 PM
  #45
5th Gear
Bossman53's Avatar
I was wondering fi there was anyway to get Mids and Highs out of the back 6x9"s while using the stock amplifier? Please let me know ASAP! I appreciate it!!!
02-25-2020 09:57 AM
CatalinaILX
ILX
10-27-2015 02:56 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
iRaw
ILX
09-05-2015 12:10 AM
Quick Reply: Finally: completed the audio system, with balun info
