Engine noise, how do i get rid of it?
Type S-man
I installed my pioneer avic-d1 and a 4-channel amp (Eclipse 3242) over the weekend. I'm running into some engine noise problems. Anyone had any experience with this or know how to get rid of it? TIA.
Type S-man
power wire was run along the drivers side. Rca's along the passenger side.
The ground connection is good too.
Anyone know what the extra thin wire is for, that is wrapped with the Rca's?
Yeehaw
Thats to use for the remote turn on for the amps.
For the noise... you are sure the ground is good, and to the frame of the car? Grounding over paint or to sheet metal causes this problem usually. If thats definitely not it, try raising the amp off of wherever its mounted, sometimes just the amp being on metal will do it.
If all else fails you can add a noise suppressor... http://www.electronixwarehouse.com/c...-sup/ans80.htm
Type S-man
the ground is to the frame, and the amps is mounted to a 3/4" mdf board...
Bump. anyone have an answer?
also, The noise does not rise when I raise the volume, if that helps any...
Type S-man
Originally Posted by dark inspire
maybe a ground loop isolator is needed?
Codename Duchess
Actually that is a drain wire for noise rejection, try grounding it at each end.
1) Make sure your RCAs are not directional, if they are and you have them reversed it can cause problems.
2) if it does not get louder with the volume it is most likely being induced after the amplifier. Make sure your x-overs (if you have any) and the amp itself are away from noise producers like ecus/pcms and the like and blower motor and other such things
3) It is probably a ground problem somewhere (for the 3rd time, probably at the amp, ck there first)...problem is, EVRYTHING electrical in the car is grounded...start checking them
Type S-man
Originally Posted by GSteg
skgarach, you're getting alternator whine correctly? As in the noise alternates as you rev the engine?
Type S-man
also, where's the best place to ground the amp in the trunk? Right now its grounded to a piece of metal right behind (nearer to the taillights) the trunk access door. From the DIY, i couldn't tell where he grounded his cable.
Codename Duchess
If you want to be anal use a voltmeter to read what voltage your battery sits at then use a ground that gets you as close to the reading as possible.
So
I know it is not getting louder when you turn the volume up! But does it get louder as the rpm's of the car goes up? If so, it is definately a ground issue! Either a ground loop or something! The ground wire coming off the amp should be as short as possible! Perferably 1.5 -2 feet! As close to that as possible! On the cars these days it doesnt have to be directly to the frame! As a main frame is almost nonexistant on newer cars today! A weld point anywhere on the body is usually fine!!! I did it to a spot weld close to the spare on mine, and I have no noises whatsoever!! I am going to add pictures of my system tomorrow!!
http://milo.smugmug.com/gallery/1007946/1/46645452
Type S-man
i tried a couple of different grounds yesterday and it didn't make a difference. So for the time being, i just turned down the gain on my amplifier so the noise is less noticeable.
As for the noise, it doesn't increase in volume when the engine is revved, but does increase in frequency and pitch.
Type S-man
Originally Posted by CivicEx1998
why dont try to lower the gain on the Amp? It helped on my old alpine amps alot.
Do you have any other suggestions El Duderino?
I'm not eldude, but....
You can try (for a test) running a ground from the Head unit ground to the amp ground.
Or maybe an inline power filter to the HU?
Or maybe a ground loop isolator if you haven't already.
Good luck!
Good luck!
Newbie 2002 TL
Hey I just finished installing an Eclipse Nav Unit and 2 amps in my car also. Spent the whole weekend doing this. After the install I'm experiencing really, bad whinning noise.One is under the seat and i've been able to isolate the noise and determined that it's the Amp in the trunk that's creating the alternator noise. I've checked my grounds, and sanded off the paint. I have a 3ft ground connected to the right of my wheelwell. I just unscrewed a bolt and sanded the area. and made sure i used a flat washer. I have been reading that even replacing the rca cables to "zero noise" insulated would help. but that means i'd have to shell out another $100+ for cables that may or may not work. Any help or suggestions is much appreciated.
Newbie 2002 TL
hey thanks for the offer. i may take you up on it. but i'mma spend this weekend rewiring everything again. and see if i made any mistakes. if not. I'll look to install a ground loop isolator 1st and try better rca's 2nd. if not I'll let you know
snorf
11-04-2019 06:44 AM
sockr1
10-01-2015 01:31 AM
Mike Bertram
09-10-2015 09:27 AM
