Does anyone have a 15" subwoofer in their 2nd gen TL
robstltype-s
I was wondering if anyone had a 15" subwoofer in their 2nd gen TL. And if so do they fit alright, and is there enough trunk room to accomadate the box it would take to utilize the sub correctly.
I have a 15 type R in my CL, it fits fine but if you have navigation it gets tricky, i had to build a special box to fit it deeper in the trunk so it would look ok, i have about 1 inch clearance from the sub to the navigation.
It actually sounds pretty damn good with the bose, neither is too overpowering which is a problem i had in my other car. The noise cancelling material throughout the acura does a pretty good job of containing rattles and only improves sound quality without muffling all the bass. My only complaint is how it sounds on the outside b/c it doesnt have 4 bolt holes for the licence plate it only has two and that makes an annoying rattle.
thats the clearance ive got
I used to use foam tape but that sounds a lil better im going to try that when it gets warmer out, if the temp is below 35 degrees i lose all motivation to do anything to my car unless its neccesary lol, i hate not having a heated garage
I dont remember the exact number, nor do i remember the dimensions i just know i went to alpine and looked at specs for the sub and looked at specs for a sealed enclosure then i built the box to the max spec. I used the formula and it is fine, if you think that box is small, you should have seen my older one.
Yeah eggy dont take it personally but im gonna follow alpines guidelines for a box rather then yours, 3.5 to 4 cubic feet? Do yourself a favor go to alpines website, look up the SWR-1542D reference manual, page 4 you will find the optimum Sealed and Vented dimentions. 1.7 to 2.5 internal volume for sealed(Mines 2.3) and 2.9 for ported. If you are telling me Alpine is lying to their customers on their specs so their merchandise does'nt sound as good as it should, well then you have a problem
my first sub was a 15 inch type r..had it in 2.5 cubes tuned to 34hz..sounded like crap..got advice from caraudio.com(biggest car audio forum on the net) guys told me to put it in 3.5-4 cubes tuned to 32..put it in 4 cubes tuned to 32..sounded ALOT better..
I guess it depends on what you are going for. Sound quality or loudness, I preffer quality and loundness I dont know what you are going for, but sealed is for quality and ported is for loudness i preffer sealed but keep in mind this is just my
you bought the wrong sub then my friend..you can't just put any sub in a sealed enclosure and except sound quality..the type r is a spl sub..shoulda got a type x
Bah, haha you guys should see my trunk the entire thing like....pumps outwards shakes up and down, it freaking rediculous im waiting for it to just explode off the car haha. But seriously do you guys know what makes the most rattle so i can fix it? I already fixed the plate i tried adding foam to every place the trunk makes contact with the car but no go. Im pretty sure 80 percent of it is from the lock, how would i go and make it so the lock doesnt make any noise?
NOT my TL or ME
1' thick dense foam
Try and adjust the rubber stoppers on the trunk lid to lower the resting height.
I havent tried to adjust the stoppers, nor deaden the trunk. I put foam where the stoppers touch and all along the bottom where the lid meets back bumper. As far as plate goes i made an x of double sided tape and stuck on 3 millimeter foam then screwed it down and no more plate rattle.
deal with it
not always true...i put on the wings west flush mount spoiler and it actually stopped most of the rattle...but in my case i didn't have a spoiler on the car at all, and the added weight pushed the lid down now i barely have any rattle, my plate rattles more than my truck
emailnatec
29
09-28-2018 04:27 PM
kb1rl
09-30-2015 10:17 AM
RSpyder
09-30-2015 12:46 AM
