DIY for installing amp and sub to factory radio
i have 99 acura tl and i really need help installing so if someone can give me instructions and pics would be nice!
to hook up your aftermarket amp here are your steps:
1) you need to run your pos battery wire from your battery to your amp. That goes to your amp, put that where it's labeled "B+" So you need to find a way to do that. Make sure you use a proper inline fuse too. 2) There is a "GRD" labeled on your amp. Make sure it is never smaller than the one above. This will be your ground wire, and most just bolt it to there seat belt bolt. But it needs to be drilled to the frame of the car. 3) There is another wire that needs to be hook up which is your remote wire, labeled "RMT" on your amp. Should be around 16awg wire size. One end of the wire goes into the "RMT" on your amp and the other taps into #2 in the above picture. This wire will turn the amp on when you turn on/off with the head unit. 4) RCA need to be hook up. You need to go buy an adapter http://img339.imageshack.us/img339/1633/dscf4425g.jpg Uploaded with ImageShack.us (Got the picture from another guy on this forum) Twists the gray/blk and the wht/blk together and tap that into slot #10 in the above picture. Now twist teh white and gray together and tap that into slot #3. the rest should be self pretty easy let me know if you have anymore questions. |
this solution is wayyyy simple I used this for my first setup..... its plug and play with the the factory stereo that lets u add an after market amp to it... http://www.sonicelectronix.com/item_...OEM-HON20.html
Originally Posted by oeasy
(Post 12069759)
| All times are GMT -5. The time now is 12:38 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
