Can viper 791 make a car idle badly
My 2001 acura cl-s is idling funny, I remember the shop messing with my pager/autostart alarm and then almost immediately afterwards the car has been idling funny, almost for the last year. It only does it about 25% of the time, but I was just wondering if since it can control the ignition, if it could play a factor in my problem....I have checked some stuff, replaced some stuff and of course the dealership can never get the damn thing to do it again...any help is appreciated
Originally Posted by KaMLuNg
please explain idle funny... is it too low, too high??? sporadic???
the only thing that your autostart should tie into are the starter lines and the tach if it uses it to sense the engine is running... but shouldn't be anything with idle...
Originally Posted by seanranger3
when the last plugs, air filter, been changed
does this occur right at cold startups?
Is there any connection that could have not been soldered properly or not hooked up correctly. I remember it starting shortly after getting my viper alarm worked on. I vaguely remember him taking my engine cover off and wondering wtf...
If he took the engine cover off, it may have been to run a tach wire. (I am guessing)
I would check your injectors to make sure they are plugged in correctly, and I could check to make sure there isn't any broken wire's where he may have tapped in...
It's just a theory.
It's just a theory.
Mike Bertram
09-10-2015 09:27 AM
