Buzzing from Tweeters and solutions?
Cruise Missile Lobber
I'm getting some buzzing from my tweeters every now and then when the right note/tone is in a song. My question is will a new set of tweeters fix the problem, or is it the fact that the crossover funtion built into the OEM amp just that crappy?
I'm willing to buy a nice set of tweeters or even a component set, but I'm a newb so I'm not sure what to do to fix the problem.
Thanks again in advance!
VP Electricity
1 Post
WHOOPS... I suspect the tweets are blown. No reason to think it won't happen again if it was caused by leaning on the system hard... I suspect the 6x9's trying to play bass and running out of power/clipping causes distortion to go to the tweeters...
Thanks elduderino!
Originally Posted by musicbox
I've noticed this occasionally on mine, but I think it's a FM radio/antenna issue, not a tweeter issue..
Is it only when listening to the radio and not CD?
VP Electricity
1 Post
Originally Posted by SSN_FT1(SS/DV)
So if the tweeters are blown then I should be able to hear music out of them, but only certain tones will make them buzz?? If that's the case will the new component system work...or will this just happen again?
On the other hand, this was a failure mode of palidanx' aftermarket amp... but in retail, we would ahve checked the tweeter first.
I would connect a cheap speaker like a 3.5 and see if it buzzes at the same times... that would tell you if it's the amp or the tweet.
"Blown"s a relative term... it's certainly within my experience that "blown" tweets buzz at certain notes.
Has anyone else had this issue....I've seen threads, but no solutions...help
VP Electricity
1 Post
Typically if they're factory they'll replace the tweets, and if that doesn't work THEN they'll replace the amp.
Often you can get a cheap "takeout" speaker from a cool stereo install department for free...
VP Electricity
1 Post
It's always possible, because warranty work pays 75% of customer pay, so they have a built-in incentive to blame you.
I would discuss this before the appointment. Explain that you know adding XM Radio doesn't hurt the tweeters, but you think they've gone out. Swapping the tweeters takes like 5 seconds (unwrapping them takes longer) so they may be willing to do so... but talking first is important. If the service dept doesn't know the XM is there, they may try to stick you later. If possible, find out if there is a service writer at your dealership who knows audio pretty well.
But remember, adding aftermarket equipment does NOT void your warranty, and if someone acts like it does, be prepared to walk. Also be prepared to call Acura... because calling Acura gets you a phone call from the service manager faster than anything. These guy's bonuses usually depend on NO customer complaints to Acura...
Thanks again!
Rep'n Taxbrain.com
This thread discusses the speaker buzzing.
Check it out!
https://acurazine.com/forums/showthread.php?t=13973
Check it out!
Dealer is likely to be an a$$. I recommend you remove your stuff before taking the car in. Only after they fix the OEM tweeters would I consider getting a component set.
The extra b is for byobb
I got fed up with the tweeters so I just disconnected them. It sounded so good after that so I never got around to replacing them. It takes about 30 seconds to disconnect (just carefully pry open the plastic speaker cover with a small screwdriver)--give it a try.
dainmezron
10-16-2015 06:56 PM
kb1rl
09-30-2015 10:17 AM
4drviper
09-23-2015 09:00 PM
