CL: Big 3 upgrade failed help!!!!!
#41
if your saying that each time you connect your power cable the fuse pops then at some point along your power wire is contacting ground. sometimes when running cable in tight places, it is possible the plastic cover can get torn and the wire is exposed and is in contact with a grounding point.
#43
#44
vtec kicked in yo
needs to be
alt to pos batt
batt ground to engine
batt ground to frame. thats #1
#2 is how can you mess it up lulz. make sure its a 250 amp fuse on 0 gauge wire. i dont fue mine at all and never had a problem. but its a good thing you did
alt to pos batt
cu0ngsayz (12-01-2011)
#46
I know man... I was thing the same thing... A 30 min project turned to be like 3 hrs... I tried to figure out what the heek was going on... Went through a 250a and a 300a... I thought be easy.. Got everything together all happy then plug everything back.. SPARK SPARK... The 300a caught on fire!!!! July4th under my hood... Hahah
#47
vtec kicked in yo
cu0ngsayz (12-02-2011)
#48
3.7L Nitrous Breathing CL
It's not the ends that could be your problem.
It's the wire covering, the insulating shell that when pulling it threw and around the metal body gets skinned to expose the bare wire.
Did you use a gromet going threw the fire wall ?
If your still having issues pull all your power wires and inspect for damage.
#49
Didn't run anything threwq the firewall. I only have the amp power wire running all the way back and that's not giving me any problems. I'll try again after I get my car back form the shop(busted oil pan). So the alt positive is the one with the hard plastic in it am I correct?
#51
vtec kicked in yo
its the big 3. not a damn wire should leave the engine bay. OP if you are having such a hassel that your car is throwing sparks i can show you every point i ran mine . one thing you NEED to look at is the exhaughst manifold cover. your terminal may be toughing it a hair and causing the melt down. its a tight fit between that and the alt. check it and get back with me and be ready to tear stuff out if that is not the problem because i personally want to know where every wire is ran and what it looks like being there. also if you didnt crimp your wires( i use a hammer for all my 2/0) that could cause a bad connection to the ground which in turn could throw sparks when you start..
#53
vtec kicked in yo
#55
And since he can not figure out how to run 3 basic wires I assume he would have a problem even running one power wire properly.
And antonio ,what the hell kind of mess is that you have ?
Surprised you were not in op position with all the ruckus.
Clean that stuff up.
Looks like a bunch of left over wire to complete your wiring.
comming off the alt to run along the radiator support,double
Grounding to the manifold tripple
#57
I just snap pics of my grounds for you in the dark.
I removed my alt to battery wire since I was starting to go lighter with the car and am not using my system right now.
But for that follow the oem one and do it in black so it does not look stupid.
Ground to support
looks like I need to reposition one of my end covers or get a new one I can see my wire.
Ground to front of trans
Ground to support
antonio3rd (12-02-2011)
#58
vtec kicked in yo
dude i can care less what it looks like. try again but when i compete things can go wrong and need replaced fast. no reason for me to make it a show car. shit happens lol. between that and it being an unfinished ride i dont care for how it looks..
#59
vtec kicked in yo
#65
vtec kicked in yo
#68
Not the most detailed picture.
I used KnuKonceptz 0 gauge wire for my big 3 and Streetwires 0 gauge for my amp kit.
For the big 3, I used a 150A inline ANL fuse and mount the fuse/holder to the side of the battery case (the little black casing around the battery) and ran that from my + terminal, to the fuse, on top of the ratiator and down to the + on the Alt)
I used a dermel to sand a bear surface where the OEM neg chassis ground was and gounded it there. And then grounded the other wire to the block, where the OEM ground was.
I soldered all connections and I am using a Kinetik 1800 battery. LOVE the batt but Im still getting some dimming on about 1600~ watts RMS. I plan to add a small Kinetik Batt in the trunk to get rid of dimming completely but I left my stock + from the batt to the alt too, could be a reason im still getting dimming.
#69
vtec kicked in yo
#70
i get dimming with an ap1500 and a big 92ah batt with 2/0 all in the car.... you really will never stop it unless you get hid lights. i dont drop below 13 though on the brightside. and also with our CL's there is an eld sensor you need to bypass so the alt charges full time . real easy to do.
I know that I dont expect to get rid of ALL dimming, just as I expect not to get rid of ALLL the rattling. But I want the second batt to keep me above 13 at all times. I drop to about 12.7 with lights on and Bass HITTING!
Does the TL have this ELD sensor?? Hmm interesting...can you explain more?
#71
vtec kicked in yo
Get HID lights? I have HIDs in all 4 housings (lows and fogs). I meant dimming as in my dome lights and gauge clusters or tail lights when breaking.
the eld sensor shuts the alt off while driving to save gas. to find out if you have one look for this
that green/red wire and the solid black one need to be connected with a 820 ohm resistor and left unplugged. i charge at 14.4 cold and 14 hot now. and fans turn on then i lose like .5v and lights are .2v....
here is my build log if you want a peek at what i run. the amp is only temp
http://www.caraudio.com/forums/car-a...l-rebuild.html
yeah i know my car is dirty. its made to get loud not stay show car lulz.
if you need help or have questions go ahead and ask. if i know it i will help. but i wont lie and say i know 100% of everything
#72
Oh no I AM VERYYYY confident in my skills and knowledge about audio.
Thank for you the knowledge on this ELD sensor. Ill take a look under my hood. This harness is located in your FUSE box under the hood correct?
#73
vtec kicked in yo
#74
And HIDs ONLYYY use more power at start up but while they are on they consume less power than Halogens. My HIDs DO NOT dim just any other bulb hahah.
And my Lowbeam HIDs are aftermarket CANBUS Ballasts, meaning they have capatitors inside the ballast to store energy. But thats besides the point.
Yeah check mine out too. tl.acurazine.com/forums/showthread.php?t=840299
kb1rl
09-30-2015 10:17 AM
