Best Speaker Wires // Sub Wires
Which are the best speaker cables to get from monster, if money wasn't an issue, i need speaker wires for my fronts/backs/sub, thanks
http://www.monstercable.com/caraudio1/speaker_cable.asp
-S namyaC-
If money wasn't an issue? The top two. But I think it's silly unless the rest of your system is that good.
For your sub, use 8ga power wire. The less resistance (larger the wire), the better it holds the amplifier's damping factor.
-S namyaC-
Generally 20% of your speaker cost is suffient on wire. $200 speakers=$40 wire. Reallly, some nice 16ga with a tough jacket should be just fine. No need to spend the extra money in this case.
Same reccomendation with the sub, larger wire you can get. 8ga is prob the max, but if you can't get that then 10 or 12.
polish_pat
09-25-2015 12:24 PM
