Best LOC for 05 TSX with nav and xm????
I'm adding a single mono amp and a sub to my setup and removing the factory 6x9's. Whats the best converter that won't interfere with my xm and nav?
Adding LOCs wont interfere with xm or nav. The xm nav issue is only for auxillary inputs.
For now I would suggest just tapping in to the rear 6x9 speaker wires for your LOC. As far as the type of LOC goes.....no suggestions here. Make sure to use both L and R channels going in to the amp. You will need to tap in to the remote output from the OEM amp. See the DIY thread for access and the right wires to tap. Then you will need Power and ground. There are 2 good spots to get your ground. One is the back seat bolt on the drivers side. The other spot is under the trunk carpet in front of the sapre tire.
Why you disconnecting the 6x9's? You gonna totally remove them?
Eggs999bacon
09-24-2015 10:08 AM
