battery terminal question
Old Nov 17, 2003 | 08:30 PM
Gpump's Avatar
You want me to break it?
Hi again - I have a question about a battery terminal to attach amp power cable to. On previous vehicles I have simply used a spade type connector and screwed it down to the terminal, but this time I am running 4 Ga power wire and want to use a terminal connector. Are all batter terminals the same size - ie can I buy any old terminal connecor/cap and it will work? Also, if anyone has a suggestion to brand or gold vs platinum plating I'd appreciate it. Getting all the goodies together to do this around Christmas ----Thanks--Brian
Old Nov 17, 2003 | 08:43 PM
e_lectro's Avatar
Still here
Re: battery terminal question
All top mount terminals are the same, unless you start looking into really small or really large batteries
The gold vs silver vs etc is just a matter or style and looks. They all conduct electricity the same. And even if there was a bit of a difference, you would never be able to tell it in a car power situation.
Old Nov 17, 2003 | 10:06 PM
Bass Mechanic's Avatar
there are 2 different sizes, make sure you get a POS cable clamp the neg post is larger or smaller i forget which.
Old Nov 18, 2003 | 12:30 AM
RA121724's Avatar
Re: Re: battery terminal question
They re the same at 1st, but the gold will not oxidize over time.
In the long run Gold connectors are better for that reason alone.
cycdaniel
Dec 17, 2019 10:58 AM
BoricuaTL
Apr 8, 2016 01:08 PM
MoAbbas
Oct 3, 2015 07:44 AM
datadr
Sep 12, 2015 09:12 PM
Phambam12
Sep 6, 2015 06:57 PM
