Batcap or second battery
i dunno what the hell a batcap is, but if your gonna be running 1000watts... you should just upgrade the battery. if u lreave it as it is now, the headlights will probably dim evertime ur system hits hard, so an upgraded battery will take care of that.
ive got a second battery and i think it was helpfull...i have no fear of draining my normal car battery now....and i can run my system even if my car was off...the only downside i think is that it weighs alot...
I checked their website and couldn't get a model number to fit the 2003 TLS. What is the model number you're using?
My JBL BP1200.1 is making my lights dance like a friggin spectrum analyzer or something. I'm thinking of going with a two battery setup since njtls made an excellent point concerning why not go with two if you own two.
I'd also like to hear from someone concerning josh stein's post. If you've got a two battery setup, how did you do it?
Originally posted by stinkboy
yellow top optima, enough said.
Originally posted by josh stein
How can you have a second battery? Where does it go and how is it wired so it can re-charge from the alternator?
Originally posted by dnd2984
again when I was talkin to teh JL people they said adding a second battery also puts a burbon on the Alt. If u just upgrade the factory battery our TLs should be fine up to 1700 watts if the system isnt allways dogged out.
Originally posted by njtls
oh..and i read on the rockford fosgate site that a 120 amp alt is good for 1500 watts...but like you dont want to run it at the limit...cause once you turn on the ac and headlights your drawing more then that...thats why i went with the second batt...even tho i'm "only" running 1500 watts
When your bass hits do your lights still dim?
Unless your planning on playing your system without running your car i would not suggest getting a second battery as each additional battery also adds a load on your alternator....unless you use a battery isolator in which case the alternator switches between the two batteries and only charges one at a time and >>> isolates<<< it from the other one. I would still suggest getting one or more large capacitors because they provide instant power on demand and recharge in no time... they also help to smooth out and regulate the voltage during peak demands of power.Before i forget, if you are doing a multi-battery set up make sure you get a isolator that is rated for your application.Ohh and this last thought...Optima Batteries or the exide orbital which is the equivelant are lower in resistance to lead acid batteries and provide the same if not more CCA's and standby time which will also be an advantage ....do not mix and match batteries either .....meaning a deepcycle battery and regular one.
Check the calculation specs on this page: http://www.eatel.net/~amptech/elecdisc/caraudio.htm
Go to the links on the right hand side and click the one labeled "Wire". Based on the amperage requirements of my particular system, I'm going to put the IDMAX back at 4 ohms and give it the 600+W that only costs me 54 amps vs. the 1 ohm load 1200W setup that is costing me 109 amps.
It looks to me like the only way to truly remedy the situation is to upgrade the alternator to roughly 180 amps or so. Since I'm not ready to go that route....yet....I'll see if I can live with the 4 ohm setup now that I was informed about the JBL mod and have heard the difference it made.
YMMV, but I think this site is worth a look. You can input all of the wiring characteristics as well as Class AB vs D to get the total amperage draw of your system. If it's over 120 amps, it's only a matter of time before your alternator dies...which won't be covered under warranty when they see your sound system!
Keep in mind what that number jumps to when you have the headlights, AC/Heat, and wipers on!
Originally posted by bozzchem
I hate to say that I find that very hard to believe. If the alternator puts out 120 amps, that means the sound system can't pull much more than 100 or so without affecting the longevity of the alternator.
When I went to the "Power Design Assistant" at the website I listed previously and input my front class AB amp at 300W and my rear class D amp at 1200W, the combined amperage draw was 152 amps!! There's no way in hell a 120 amp alternator is going to keep that up for long. By dropping the class D to 600W, my total draw will be 97 amps. That shouldn't be too big of a problem for a 120 amp alternator....until you add the headlights, fog lights, wipers, heater/AC, etc.
I'm sorry I'm rambling on about this but I'm really trying to figure out the best approach to take to remedy this situation.
Thoughts?
It costs nothing to rewire the sub. I figure the alternator will be ~$200 or so.
MetalGearTypeS
08-29-2016 08:28 PM
