amp placement
DO WORK!
1 Post
amp placement
so i took out my spare tire and placed my amp in that spot, should i try to add means of cooling or do you guys think it will b ok there underneath the carpet cover? what could i do to add cooling down there? thanks
yeaa... relocate bro... mine gets really hot just sitting in the trunk it self... i havent even mounted it yet :/l... prolly should do that because it jus has freedom to move aroundin the back...
gistered User
Originally Posted by DiaBando
Absolutely!! What amp are u running?
gistered User
My gear is spread out all over the FB (see my signature)-then covered with a shaped FB 'lid' in 2 sections over that, pretty stealth-except for the sub, and the amps get warm to the touch-but nothing disconcerning even in summer. What power cable size are you running? Again, even warm, good amps are designed to take the confinement. Does JL offer a cooling system?
DO WORK!
1 Post
im running 4 guage wires, for power and ground. the JL amp does not have a cooling system. but i read in the manual that they say its ok to mount underneath a seat if there is atleast 1inch of clearance above the top of the amp, so i dont think it should be an issue if i have it in the spare tire compartment.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
^^^ Was just going to recommend mounting to the back of the seat, much better for the heat to dissipate
InFaMouSLink
10-30-2015 09:43 AM
4drviper
09-23-2015 09:00 PM
Pegon95
09-15-2015 01:54 PM
